Hi there,
I’m very new to LibreNMS and managed to install it on a ‘fresh’ CentOS7 vm.
Current version: 21.1.0-33-g291f90a - Tue Feb 16 2021 04:04:23 GMT+1300
I understand I can customize poller modules straight from Web UI (Global) but also get more specific to OS level by adding $config parameters to config.php
Example:
$config[‘os’][‘ios’][‘poller_modules’][‘cisco-ace-serverfarms’] = 0;
$config[‘os’][‘ios’][‘poller_modules’][‘cisco-ace-loadbalancer’] = 0;
$config[‘os’][‘ios’][‘poller_modules’][‘cisco-cbqos’] = 1;
$config[‘os’][‘ios’][‘poller_modules’][‘cisco-cef’] = 1;
$config[‘os’][‘ios’][‘poller_modules’][‘cisco-mac-accounting’] = 1;
$config[‘os’][‘ios’][‘poller_modules’][‘cisco-voice’] = 0;
$config[‘os’][‘ios’][‘poller_modules’][‘cisco-remote-access-monitor’] = 0;
$config[‘os’][‘ios’][‘poller_modules’][‘cisco-sla’] = 0;
$config[‘os’][‘ios’][‘poller_modules’][‘cisco-ipsec-flow-monitor’] = 0;
$config[‘os’][‘ios’][‘poller_modules’][‘cipsec-tunnels’] = 0;
$config[‘os’][‘ios’][‘poller_modules’][‘cisco-otv’] = 0;
$config[‘os’][‘ios’][‘poller_modules’][‘cisco-vpnd’] = 0;
Now, I couldn’t find this on the docs but that might have just been me being overwhelmed.
There are ‘definitions’ (yaml files) under ./include/definitions/ for the different platforms and devices so here is one of my questions.
1.- If I edit these, to make, let’s say, ios to have most of these modules set as false.
Do these changes survive and update/upgrade?
When are these definitions being read? Every time I add a new device that matches the definition?
This is just to understand how it works and when I should expect these changes to take effect.
I suspect these changes won’t retrofit existing devices matching the same definition, am I correct?
Example of the above:
poller_modules:
cisco-ace-serverfarms: false
cisco-ace-loadbalancer: false
cisco-cbqos: true
cisco-cef: true
cisco-mac-accounting: true
cisco-voice: false
cisco-remote-access-monitor: false
cisco-sla: false
cisco-ipsec-flow-monitor: false
cipsec-tunnels: false
cisco-otv: false
cisco-vpdn: false
ipmi: false
- [EDIT] It seems these poller modules are MIBs, are they all MIBs? if poller modules = snmp, the answer is probably yes, correct?
Thanks for the time and keep up the good work
