Poller Not Working Properly -- Running Slow
I’m polling 3 devces:
Last week all of a sudden librenms / poller specifically just starting having issues.
Large poll times (maybe infinite) and huge gaps in graphs.
Tried basic steps, a reboot of the box / services
Polling all devices from cli and that itself is taking a long time, usual poll time was around ~8s
Not sure what happened, also removed the poller from the webui and was going to re-add but not sure how to do that.
From the looks of it my install appears borked.
validate.php
warning: unable to access '/home/a/.config/git/config': Permission denied
LibreNMS  | 1.61-18-gc4eb412e2
DB Schema | 2020_02_10_223323_create_alert_location_map_table (159)
PHP       | 7.2.24-0ubuntu0.18.04.3
MySQL     | 10.1.44-MariaDB-0ubuntu0.18.04.1
RRDTool   | 1.7.0
SNMP      | NET-SNMP 5.7.3
[OK]    Composer Version: 1.9.3
[FAIL]  The poller has never run or you are not using poller-wrapper.py, check the cron job.
[WARN]  Some devices have not been polled in the last 5 minutes. You may have performance issues.
	Devices:
	 131.x.x.x
	 131.x.x.x
	 localhost
[FAIL]  Some devices have not completed their polling run in 5 minutes, this will create gaps in data.
	Devices:
	 131.x.x.x
	 131.x.x.x
	 localhost
warning: unable to access '/home/a/.config/git/attributes': Permission denied
[WARN]  Your local git contains modified files, this could prevent automatic updates.
	Modified Files:
	 bootstrap/cache/.gitignore
	 logs/.gitignore
	 rrd/.gitignore
	 storage/app/.gitignore
	 storage/app/public/.gitignore
	 storage/debugbar/.gitignore
	 storage/logs/.gitignore
[FAIL]  Some folders have incorrect file permissions, this may cause issues.
	Files:
	 /opt/librenms/bootstrap/cache/services.php
If you manually run ./poller.php -d -h anyhost you will get how many time the poller used in snmp, rrd and mysql.
Start from there to debug why is taking so many time.
Really odd, but removed my prometheus pushgateway config and things look better.
Running that command, it halted at the prometheus piece so anyway obvious change, will monitor.
pushgateway functionality is important since most people outside of our team use prometheus and grafana… has there been any additional work on that piece or still Alpha/Beta?
Afaik, still alpha/beta but I believe something is going on and probably will see the light very soon for testing.
I use influxdb without any issue, only when influx is down or working really low, 100% due to disk IO.
So, make sure that prometheus is working fine and you dont have connectivity issues betwen it and your librenms
Exactly what I’m verifying with the team that manages the prometheus infrastructure.
Thank you again!
