Gear Icon --> Poller --> Performance
The Poller Performance by Module Graphs are not populating, if I goto the URL directly and show the RRD command, it displays the really long RRD command, and at the bottom, shows:
RRDTool Output
ERROR: don’t understand ‘bgp-peersRaw0,UN,0,bgp-peersRaw0,IF’
I took the RRD command and removed all references to bgp-peersRaw[number] and rerun it in the command line, but then RRDTool will error with
ERROR: don’t understand ‘entity-physicalRaw0,UN,0,entity-physicalRaw0,IF’
There seems to be a problem with the way LibreNMS is building the RRDTool commandline for the Poller Performance by Module graphs on my setup. Any ideas where to begin to fix this?
- The output of
./validate.php
./validate.php is normal
Component | Version |
LibreNMS | 1.62-28-g5f2eab0 |
DB Schema | 2020_03_25_165300_add_column_to_ports (161) |
PHP | 7.2.29-1+ubuntu16.04.1+deb.sury.org+1 |
MySQL | 10.0.38-MariaDB-0ubuntu0.16.04.1 |
RRDTool | 1.5.5 |
SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.10.1
Not sure if this is relevant, but I have previously disabled the BGP module as I don’t need it. Re-enabling it does not help.
