Poller Problems
On Web Interface
PollerFailure
FAIL: No active polling method detected
OK: Dispatcher Service not detected
OK: Locks are functional
FAIL: No active python wrapper pollers found
OK: Redis is unavailable
on ./validate.php
LibreNMS 23.11.0-4-g6d0e07922 (2023-11-18T06:28:59+03:00)
DB Schema 2023_11_04_125846_packages_increase_name_column_length (273)
PHP 8.1.2-1ubuntu2.14
Python 3.10.12
Database MariaDB 10.6.12-MariaDB-0ubuntu0.22.04.1
SNMP 5.9.1
[OK] Composer Version: 2.6.5
[OK] MySQl and PHP time match
[FAIL] No active polling method detected
Any Solutions please?
You aren’t running either the cron job or the librenms python script. Have a look at Dispatcher Service (RC) - LibreNMS Docs
If not, go through the original install docs as you’ve missed the cron setup.
