Hi guys,
I am new both to LibreNMS and my Linux knowledge are not very vast
I had my LibreNMS installed by one of my colleagues in a docker and everything worked just fine until I did the upgrade to the newest version.
After the upgrade I had the errors with the database schema but after running the ALTER TABLE commands I did not have the errors anymore.
However, the poller does not work anymore and the graphs are empty :-/
I did stop and restarted the services, restarted the machine but with no result.
Here’s the output from validate:
Component | Version |
LibreNMS | 21.3.0 |
DB Schema | 2021_03_17_160729_service_templates_cleanup (201) |
PHP | 7.4.15 |
Python | 3.8.8 |
MySQL | 10.2.37-MariaDB-1:10.2.37+maria~bionic |
RRDTool | 1.7.2 |
SNMP | NET-SNMP 5.9 |
[WARN] Log rotation not enabled, could cause disk space issues
sudo cp /opt/librenms/misc/librenms.logrotate /etc/logrotate.d/librenms
These being said, I’m in a dead end and I don’t know what else to do to fix it.
Thank you!
