| LibreNMS | 1.64.1 |
| DB Schema | 2020_04_06_001048_the_great_index_rename (165) |
| PHP | 7.4.6 |
| Python | 3.6.8 |
| MySQL | 5.5.65-MariaDB |
| RRDTool | 1.4.8 |
| SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.10.6
After upgrading to the latest release with ./daily.sh im getting “Devices unpolled” error. Initially i thought it the poller wil cycle itself, then i rebooted to no avail. If i run poller.php it works, but when i do poller-wrapper.py im getting could not connect.
[librenms@librenms ~]$ ./poller-wrapper.py
ERROR: Could not connect to MySQL database!
ERROR: (2003, “Can’t connect to MySQL server on ‘localhost’ ([Errno 111] Connection
refused)”)
I dont know if this is relevant or related but, im also getting phyton warning in the WebUI
Warning: Could not check Python dependencies because this script is not running as librenms
this is Centos7 vm image i downloaded and imported in our proxmox.
Please let me know if you need anything else in order to resolve this issue
Thanks,
Mladen
