Polling processor
Who knows why i can not have the polling for cpu
I do not have its display
in defaults.inc.php
$config[‘poller_modules’][‘processors’] = 1;
hi romain,
validate your install
to validate your install run ./validate.php and then paste your results so we can help you.
hi @Kevin_Krumm
for the data bases i think it’s because i use the database generated with the old version of librenms but why i can’t rebuild new shema
thank you for your help
I’m sorry romain,
I’m not much a database guy… Personally, i would do a fresh install that is updated with the master. Maybe someone else will chime in :frowning:
You can just run those two mysql queries.
For the cpu you need to post the output of ./discovery.php -h HOSTNAME -d -m processors
Thank you for the discovery it works now but by adding 500 devices and even adding the max_connexion for the data base mysql but now the platform is very heavy and even the machine
And yet I have no problem memory
tail -l logs/access_log
/537.36 (KHTML, like Gecko) Chrome/58.0.3029.110 Safari/537.36"
10.26.238.65 - - [15/Jun/2017:16:36:09 +0200] “GET /ports/ HTTP/1.1” 500 - “-” “Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/58.0.3029.110 Safari/537.36”
is it possible to rebuild the data bases shema ???
