I’m running LibreNMS in AWS to monitor about 250 sites nation wide. In each site I have about 5 switches. I keep getting this message most of the time:
Polling took longer than 5 minutes! This will cause gaps in graphs.
I have performed all the optimization for performance steps mentioned in LibreNMS site. Can someone give me more information on how to optimize my instance for better outcome? can I schedule the polling or something since I have around 900 devices on my network?
I have also change those file permission always, and they come back again asking me to change ownership every few days.
Steps to reproduce an issue.
It happens from time to time, no specifics and not able to repeat it manually. -
The output of
./validate.php
[[email protected] ec2-user]# /opt/librenms/validate.php
LibreNMS | 1.48.1-59-g4504b20
DB Schema | 2019_01_16_195644_add_vrf_id_and_bgpLocalAs (131)
PHP | 7.2.14
MySQL | 5.5.60-MariaDB
RRDTool | 1.4.8
SNMP | NET-SNMP 5.7.2
[OK] Composer Version: 1.8.4
Devices:
90100swtennis1.compux.com
92662sw5.compux.com
92175sw4.compux.com
90192sw4.compux.com
91054sw8.compux.com
91099rtr1.compux.com
93083sw2.compux.com
90522sw3.compux.com
10.127.4.12
90632sw2.compux.com
91556swgolfshop.compux.com
90100rtr1.compux.com
and 37 more…
Files:
/opt/librenms/storage/framework/views/cbecc806413997036d8bb74bf909c50d
Thank you,
Hosam
