Steps to reproduce an issue.
Run poller script on the debug page, https://[librenms-url]/device/[14device-id]/capture
The issue started for me 2020-05-15 00:15:05 CET -
The output of
./validate.php
$ ./validate.phpComponent Version LibreNMS 1.63-87-g4edff1e88 DB Schema 2020_04_13_150500_add_last_error_fields_to_bgp_peers (164) PHP 7.4.6 Python 3.6.9 MySQL 10.1.44-MariaDB-0ubuntu0.18.04.1 RRDTool 1.7.0 SNMP NET-SNMP 5.7.3 ====================================
[OK] Composer Version: 1.10.6
Output of the above
$ ./discovery.php -h HOSTNAME -d | ./pbin.sh
Paste endpoint: https://p.libren.ms/api/create
SQL[select migration
from migrations
order by id
desc limit 1 [] 0.19ms]
SQL[select count(*) as aggregate from `migrations` limit 1 [] 0.1ms]
SQL[SELECT version() [] 0.12ms]
Updating os_def.cache...
Done
SQL[SELECT * FROM `devices` WHERE disabled = 0 AND snmp_disable = 0 AND `hostname` LIKE 'HOSTNAME' ORDER BY device_id DESC [] 0.51ms]
./discovery.php HOSTNAME 2020-05-16 11:00:45 - 0 devices discovered in 0.097 secs
title:
private: 1
expire: 0
https://p.libren.ms/view/d049aaaa
$ ./poller.php -h HOSTNAME -r -f -d | ./pbin.sh
SQL[select `migration` from `migrations` order by `id` desc limit 1 [] 0.32ms]
SQL[SELECT version() [] 0.26ms]
Done
SQL[SELECT * FROM `devices` WHERE `disabled` = 0 AND `hostname` = 'HOSTNAME' ORDER BY `device_id` ASC [] 0.48ms]
./poller.php HOSTNAME 2020-05-16 11:01:11 - 0 devices polled in 0.098 secs
title:
private: 1
expire: 0
https://p.libren.ms/view/b12264bb
My issue, the result of the debug pooler:
Argument 1 passed to LibreNMS\Modules\OS::updateLocation() must be an instance of LibreNMS\OS, string given, called in /opt/librenms/LibreNMS/Modules/OS.php on line 80 {“exception”:"[object] (Symfony\Component\Debug\Exception\FatalThrowableError(code: 0): Argument 1 passed to LibreNMS\Modules\OS::updateLocation() must be an instance of LibreNMS\OS, string given, called in /opt/librenms/LibreNMS/Modules/OS.php on line 80 at /opt/librenms/LibreNMS/Modules/OS.php:103)"}
In OS.php line 103:
OS.php on line 80
Here is the whole debug message:
LibreNMS Poller
SQL[select `migration` from `migrations` order by `id` desc limit 1 [] 0.19ms]
Version info:
Commit SHA: b9c2f750924597ab4fec2ee6b75cb77b138069d2
Commit Date: 1589616886
DB Schema: 2020_04_13_150500_add_last_error_fields_to_bgp_peers (164)
PHP: 7.4.6
MySQL: 10.1.44-MariaDB-0ubuntu0.18.04.1
RRDTool: 1.7.0
SNMP: NET-SNMP 5.7.3
Warning: file_put_contents(/opt/librenms/cache/os_defs.cache): failed to open stream: Permission denied in /opt/librenms/includes/common.php on line 1424
Done
Starting polling run:
SQL[SELECT * FROM `devices` WHERE `disabled` = 0 AND `hostname` = '[IP Hidden]' ORDER BY `device_id` ASC [] 0.42ms]
SQL[select * from `devices` where `device_id` = ? limit 1 [14] 0.24ms]
Hostname: [IP Hidden]
Device ID: [Device id Hidden]
OS: samsungprinter
SQL[select * from `devices_attribs` where `devices_attribs`.`device_id` = ? and `devices_attribs`.`device_id` is not null [14] 0.1ms]
(printer)
SQL[select `hostname`, `overwrite_ip` from `devices` where `hostname` = ? limit 1 ["[IP Hidden]"] 0.24ms]
[FPING] '/usr/bin/fping' '-e' '-q' '-c' '3' '-p' '500' '-t' '500' '[IP Hidden]'
array (
'xmt' => 3,
'rcv' => 3,
'loss' => 0,
'min' => 0.32,
'max' => 0.52,
'avg' => 0.44,
'dup' => 0,
'exitcode' => 0,
SQL[INSERT IGNORE INTO `device_perf` (`xmt`,`rcv`,`loss`,`min`,`max`,`avg`,`device_id`,`timestamp`,`debug`) VALUES (:xmt,:rcv,:loss,:min,:max,:avg,:device_id,NOW(),:debug) {"xmt":3,"rcv":3,"loss":0,"min":0.32,"max":0.52,"avg":0.44,"device_id":14,"debug":"[]"} 9.86ms]
SQL[UPDATE `devices` set `last_ping`=?,`last_ping_timetaken`=? WHERE device_id=? ["2020-05-16 10:55:16",0.44,14] 7.13ms]
SNMP Check response code: 0
Modules status: Global+
OS
Device
#### Load poller module core ####
SNMP['/usr/bin/snmpget' '-v2c' '-c' 'COMMUNITY' '-OQnUt' '-m' 'SNMPv2-MIB' '-M' '/opt/librenms/mibs' 'udp:HOSTNAME:161' 'sysUpTime.0' 'sysContact.0' 'sysName.0' 'sysObjectID.0' 'sysDescr.0']
.*.*.0 = 2815277287
.*.*.0 = [Email Hidden]
.*.*.0 = [Device name Hidden]
.*.*.0 = .*.*.5.1
.*.*.0 = Samsung Samsung M283x Series; V* MAR-11-2016;Engine V1.00.12 08-11-2015;NIC 31.03.60_0.1_13-11-18;S/N [Removed Serial number]
SNMP['/usr/bin/snmpget' '-v2c' '-c' 'COMMUNITY' '-OQnUst' '-m' 'HOST-RESOURCES-MIB:SNMP-FRAMEWORK-MIB' '-M' '/opt/librenms/mibs' 'udp:HOSTNAME:161' 'snmpEngineTime.0' 'hrSystemUptime.0']
snmpEngineTime.0 = 28152772
hrSystemUptime.0 = 240492200
Uptime seconds: 28152773
Uptime: 325 days 20 hours 12 minutes 53 seconds
>> Runtime for poller module 'core': 0.0118 seconds with 22168 bytes
>> SNMP: [2/0.01s] MySQL: [0/0.00s]
#### Unload poller module core ####
Modules status: Global-
OS
Device
Module [ unix-agent ] disabled globally.
OS
Device
#### Load poller module os ####
Attempting to initialize OS: samsungprinter
Attempting to initialize OS: printer
OS initialized as Generic
SNMP['/usr/bin/snmpget' '-v2c' '-c' 'COMMUNITY' '-OQv' '-M' '/opt/librenms/mibs' 'udp:HOSTNAME:161' '1.3.6.1.4.1.236.11.5.11.53.31.1.4.0']
"M283x Series"
SNMP['/usr/bin/snmpget' '-v2c' '-c' 'COMMUNITY' '-OQv' '-M' '/opt/librenms/mibs' 'udp:HOSTNAME:161' '1.3.6.1.2.1.43.5.1.1.17.1']
"[Removed serial number]"
Argument 1 passed to LibreNMS\Modules\OS::updateLocation() must be an instance of LibreNMS\OS, string given, called in /opt/librenms/LibreNMS/Modules/OS.php on line 80 {"exception":"[object] (Symfony\\Component\\Debug\\Exception\\FatalThrowableError(code: 0): Argument 1 passed to LibreNMS\\Modules\\OS::updateLocation() must be an instance of LibreNMS\\OS, string given, called in /opt/librenms/LibreNMS/Modules/OS.php on line 80 at /opt/librenms/LibreNMS/Modules/OS.php:103)"}
In OS.php line 103:
OS.php on line 80
Sorry I’ve never used pastebin before, so this post is a bit long.
