I recently started using a Cisco IE-3300-8T2S with the 16 port expansion module. I noticed that in LibreNMS (as pictured) the link to the neighbor device (far right column) is displaying incorrectly. The link to the neighbor that is displayed belongs to the port that is next in line. This is true for ports GigabitEthernet2/1-16. I have not seen a workaround for this. Other devices that have an AppGigabitEthernet port such as a Cisco C9300 do not have this problem seemingly because the AppGigabitEthernet port falls after all of the physical ports and not in the middle like with the IE-3300-8T2S with the 16 port expansion module. Any advice on resolving this would be appreciated.
Output of ./validate.php
librenms@ic-ot-nms-01:~$ ./validate.php
| LibreNMS | 24.4.1 (2024-04-20T09:26:51-05:00) |
| DB Schema | 2024_04_10_093513_remove_device_perf (292) |
| PHP | 8.1.27 |
| Python | 3.8.10 |
| Database | MariaDB 10.3.39-MariaDB-0ubuntu0.20.04.2 |
| RRDTool | 1.7.2 |
| SNMP | 5.8 |
[OK] Composer Version: 2.5.8
[WARN] Your database schema has extra migrations (2020_02_25_101056_create_ports_lldplocportid_table). If you just switched to the stable release from the daily release, your database is in between releases and this will be resolved with the next release.
librenms@ic-ot-nms-01:~$ ./da
daily.sh database/
librenms@ic-ot-nms-01:~$ ./daily.sh
Fetching new release information OK
Updating to latest release OK
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
- The output of
./validate.php
