When trying to set the port association mode on a VM it fails.
We have several VMs that “bounce” ports this has caused the port numbers to grow substantially. I have cleaned them up now so only down to a couple hundred rather than millions.
I saw in a couple other post to change the ifindex to ifName under the SNMP setting of the WebUI
When I did that I get an error
Blockquote
Could not conned to with those SNMP settings. To save anyway. turn on Force Save
Blockquote
Output from Validate
./validate.php
| LibreNMS | 22.12.0 (2022-12-28T10:26:21-08:00) |
| DB Schema | 2022_08_15_084507_add_rrd_type_to_wireless_sensors_table (248) |
| PHP | 8.2.0 |
| Python | 3.8.10 |
| Database | MariaDB 10.3.37-MariaDB-0ubuntu0.20.04.1 |
| RRDTool | 1.7.2 |
| SNMP | 5.8 |
So if I force save will it use the ifName or continue to use ifindex?
I would like to have it so that the ports don’t grow as fast sometime the ports can bounce several times in a day and with 30+ interfaces configured can easily be in the hundreds if not thousands in a single day between all the VM.
Does anyone have any recommendations to try and fix?
I have searched through log files and not seeing anything
