Under my switches (port settings) for description, I see you can set it manually. However, in my cisco switches I already have descriptions set under each interface.
Libre doesnt seem to be acknowledging these and bringing them into the GUI. Is it supposed to be? I don’t want to set each port descriptoin in libre as it is too time consuming.
FYI I figured it out. I had to clear out the description field in libre under the port with the issue, it switches to repoll, and then the next polling cycle it pulled in the correct description from the switch.
