Port description parsing not working if I modify the description in webui.
Added “Core: testing” as description and the port not showing up under the Port > Core menu, neither in the Port list > Port Type. Tested with Mikrotik and Pfsense.
When I add the description directly on the device, the parsing is successful. I can see the graphs under Port > Core menu for the relevant port.
librenms@hq-s-netmon:~$ ./validate.php
| LibreNMS | 23.10.0-62-g63eeeb717 (2023-11-08T15:36:09+01:00) |
| DB Schema | 2023_11_04_125846_packages_increase_name_column_length (273) |
| PHP | 8.2.11 |
| Python | 3.9.2 |
| Database | MariaDB 10.5.21-MariaDB-0+deb11u1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9 |
Best
