Port down notice per port not Per switch
Good Morning Everyone,
I have been able to get alerts working for switches and can successfully receive email notifications listing ports that are down on a device. However, in some cases, the individual ports are more important to me than the switch as a whole, and I need alerting to function on a per-port basis.
For example, I aggregate multiple ISP connections onto a front-end switch in our campus telco closet and then hand them off over VLANs to the departments that use them. In this scenario, I need to receive an alert specifically when something like UC-SWFE-01 port 1/0/23 (ISP1) goes down.
If, during that same outage window, port 1/0/15 (ISP2) on the same switch also goes down, I need a separate alert generated for that port as well. Likewise, when port 1/0/23 is restored, I need a recovery notification specifically for that port while continuing to maintain the active alert for port 1/0/15 until it is also restored.
Right now, LibreNMS sends the initial alert when the first port goes down, but any additional port failures on the same switch are simply appended to the existing alert instead of generating a new alert for the newly affected port. Additionally, when one ISP connection is restored while another remains down, the restored port does not generate a resolved notification.
My question is: Is it possible to separate alerts on a per-port basis so that each port generates and clears its own independent alert?
Edit to add LibreNMS info for version we are running
Linux: Ubuntu 24.04 LTS
We are running the Nightly updates for LibreNMS
Version 26.6.1-dev.21+91f1ce05f - Mon May 25 2026 11:32:19 GMT-0400
Database Schema 2026_05_18_120000_port_security_boolean_enable_columns (388)
Web Server nginx/1.24.0
PHP 8.3.6
Python 3.12.3
Database MariaDB 10.11.14-MariaDB-0ubuntu0.24.04.1-log
Laravel 12.58.0
RRDtool 1.7.2
Net-SNMP 5.9.4.pre2
Not supported right now
Well that’s a bummer. Thanks for the fast reply :slight_smile:
The only terrible way to do this would be to make an alert rule for each individual port. :smiley:
Yeah. We ended up making it into a service using a mix of Nagios plugins and SNMPv3.
Why is making an alert rule for each individual port a terrible idea? Specifically, how does it affect the operation of LibreNMS?
Would you be willing to elaborate on your solution? In particular, how are you using the service to generate a separate alert and recovery notification for each individual interface? Thanks.
Huge maintenance overhead for you.
I’m afraid a certain amount of administrative overhead cannot be avoided when one wants alerts for each and every port in only a certain subset of ports, whether that overhead be in LibreNMS itself or in maintaining SNMP views on the devices (as I suspect the OP is doing). I use a port group and a script to maintain the rules for each port in the port group, so the administrative overhead is reasonable. I’m not thrilled about that solution, though. And if a single service for a device can be used to generate separate Alert and Recovery email notifications for each port of interest on the device, I’d certainly like to hear how it’s being done.
I was able to build a single port nagios check and make it service. I moved it to a public repo at LibreNMS/ifstatus_single at main · Null0Engineer/LibreNMS · GitHub
I’m building support directly into LibreNMS for it: First draft of introducing faults and per entity alerting by laf · Pull Request #19891 · librenms/librenms · GitHub
Sweet i look forward to its GA :slight_smile:
Feature is now live in master.
