Hi guys, Im trying to find out why there is a vlan port missing on my router device port list.
I have other similar ports configured at same device with no problem on librenms.
Capture tools (snmp) lead me to following log message:
[2019-10-23 13:07:05] production.ERROR: The process “‘/usr/bin/snmpbulkwalk’ ‘-v3’ ‘-l’ ‘noAuthNoPriv’ ‘-n’ “” ‘-u’ ‘version3’ ‘-OUneb’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/mikrotik’ ‘-t’ ‘120’ ‘udp:172.17.50.1:161’ ‘.’” exceeded the timeout of 60 seconds. {“userId”:1,“exception”:"[object] (Symfony\Component\Process\Exception\ProcessTimedOutException(code: 0): The process "‘/usr/bin/snmpbulkwalk’ ‘-v3’ ‘-l’ ‘noAuthNoPriv’ ‘-n’ "" ‘-u’ ‘version3’ ‘-OUneb’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/mikrotik’ ‘-t’ ‘120’ ‘udp:172.17.50.1:161’ ‘.’" exceeded the timeout of 60 seconds. at /opt/librenms/vendor/symfony/process/Process.php:1237)
[stacktrace]
I already set 120 sec as you can see on -t flag , but error still there.
Also executed the command on server cli:
snmpbulkwalk -v3 -l noAuthNoPriv -u version3 udp:172.17.50.1:161
And goy an excesive snmp info … after 2 mins I had to ctrl-c to exit.
Is there something more I can tweak ?
Is it normal , that librenms request too much info from device ?
Can I manually set what ports I need ?
Other Idea to solve this ?
Regards,
Leandro.
