Port power management with ASR 9001
Hello the community,
I have a question with the port power measurement (bDm value) from the overview panel.
This problem occur with Cisco ASR 9001 routers with IOS XR 5.3.3 and satelite connected to it.
In the overview area we can see the bDm value for the 10Gig integrated interfaces.
But there is no value measured for the 1Gig ports of the satelite routers.
Generally, all this 1Gig ports are correctly seen and monitored by LibreNMS for this equipment.
Does LibreNMS can only monitor the power of integrated interfaces ?
Maybe I missed a parameter somewhere ?
Thanks a lot
Regards
Nicolas
1Gig copper ports? Are you sure they should be showing dBm values…
No it’s Fiber ports with Bi-Directionnal SFP.
Pastebin the output of ./discovery.php -h HOSTNAME -d -m sensors - I expect the device isn’t returning the info from snmp.
Sorry for the long wait … you can show the output below
LibreNMS Discovery
Version info:
Commit SHA: 2f4efb2a43f1276b55ec3e13aeeb2fd9128b107e
Commit Date: 1497995798
DB Schema: 195
PHP: 5.6.30-0+deb8u1
MySQL: 10.0.30-MariaDB-0+deb8u2
RRDTool: 1.4.8
SNMP: NET-SNMP 5.7.2.1
DB Schema update started…
DB Schema already up to date.
SQL[SELECT * FROM devices WHERE status = 1 AND disabled = 0 AND hostname LIKE ‘’ ORDER BY device_id DESC]
./discovery.php 2017-06-21 13:51:45 - 0 devices discovered in 0.011 secs
SNMP: Get[0/0.00s] Walk [0/0.00s]
MySQL: Cell[3/0.00s] Row[-3/-0.00s] Rows[1/0.00s] Column[0/0.00s] Update[0/0.00s] Insert[0/0.00s] Delete[0/0.00s]
You haven’t run the command correctly.
Ok, my bad … i made a mistake in the hostname.
This is the right output :
https://pastebin.com/aC7aG3X7
Regards
What’s the interface for the 1Gb port? GiX/X/X?
Yes, especially
Gi101/0/0/0 to Gi101/0/0/43
Gi102/0/0/0 to Gi102/0/0/43
Gi103/0/0/0 to Gi103/0/0/43
Regards
I don’t see those mentioned in the output so unless they are under different names it looks like that data isn’t sent back from your device.
Hi Iaf,
The problem was in the Cisco router directly.
My SNMP community wasn’t belong to the “sysowner” group.
Now the values are correctly seen.
Regards
