Are there any known issues with resetting of port state? I have a number of serves with docker0 interfaces (which I’ve added to “bad interfaces”) so they should be ignored but they keep alerting down then clear after a bit. I have also set all of them to ignore alerts in the port settings but the toggle keeps turning itself off again after some period of time and they begin alerting again. This only seems to happen with servers, though once in a while a switch will do it too.
It has done this for the last few librenms versions but 24.3.0 seems to have made it worse.
LibreNMS | 24.3.0 (2024-04-01T10:18:44-05:00)
DB Schema | 2024_02_07_151845_custom_map_additions (290)
PHP | 8.3.1
Python | 3.10.12
Database | MariaDB 10.6.16-MariaDB-0ubuntu0.22.04.1-log
RRDTool | 1.7.2
SNMP | 5.9.1
[OK] Composer Version: 2.7.2
