I have created an alert rule from collection.Raise an alert if the Port utilisation over 20.The utilisation have reached 90%.But still no alert is raised.
This is my utilisation rule.But i am still not receiving any alerts.Can someone please help.
That is usage percentage for IN only, and the percentage is calculated from the interface speed so make sure LibreNMS has that correct.
if you want to measure OUT then it’s macros.port_out_usage_perc
Try set it to a low value first to see if triggers at all, and change delay to 0
Hi Chas Thanks,I have created another rule with macros.port_out_usage_perc greater or equal to 5.Will wait for another 5 hours and see if its raising any alerts.
