We recently upgraded to a new server by installing LibreNMS and importing the database and copying over the rrd files. Everything works great except when clicking on the ports page for any device will bring up the 504 Gateway Time-out. No other page seems to have that issue.
nginx error log
2023/06/21 08:45:28 [error] 1322#1322: *142139 upstream timed out (110: Connection timed out) while reading response header from upstream, client: 199.192.157.20, server: apollo.netviscom.com, request: “GET /device/1239/ports HTTP/1.1”, upstream: “fastcgi://unix:/run/php-fpm-librenms.sock”, host: “apollo.netviscom.com”, referrer: “http://apollo.netviscom.com/device/1239”
php8.2-fpm has the memory limit set as 4G
./validate.php
| LibreNMS | 23.5.0-21-gf4c739c17 (2023-06-18T22:22:41-05:00) |
| DB Schema | 2023_04_27_164904_update_slas_opstatus_tinyint (252) |
| PHP | 8.2.7 |
| Python | 3.9.2 |
| Database | MariaDB 10.5.19-MariaDB-0+deb11u2 |
| RRDTool | 1.7.2 |
| SNMP | 5.9 |
[OK] Composer Version: 2.5.8
[OK] MySQl and PHP time match
[OK] Redis is functional
