Hi guys, is there a way to force ports separate SNMP walks as in Observium? At least with Juniper devices it makes a big difference in polling time.
you mean separate snmpget instead of one big snmp(bulk)walk ? if yes, the feature is “Per Port Polling” : https://docs.librenms.org/Support/Performance/
Thanks @PipoCanaja, yes, i found that but it doens’t work exactly the same way. I later found that high polling times were due to other configuration problems
