Ports shown as mpls-layer instead of normal L3 interface
Hi all,
Idk what and when changed, but our librenms shows MPLS enabled ports as f.ex. " TenGigabitEthernet0/0/26-mpls layer" instead of just “TenGigabitEthernet0/0/26”.
There is no IP info on the MPLS port and also no graph.
If I add “mpls” to badif_type, the ports are deleted in the database and don’t show up in the WebUI. When I reactivate these ports in the database, and do a rediscover, they are deleted again:
ignored by ifType: mpls (matched: mpls )
SQL[UPDATE `ports` set `deleted`=? WHERE `port_id` = ? ["1",6828299] 0.32ms]
 valid
SQL[UPDATE `ports` set `deleted`=? WHERE `port_id` = ? ["1",6828301] 0.2ms]
 valid
What option did I miss? Is there a way to have these interfaces just as normal L3 port (probably type ethernet)?
LibreNMS  | 24.2.0-30-g8c4205c61 (2024-03-19T10:24:07+01:00)
DB Schema | 2024_02_07_151845_custom_map_additions (291)
PHP       | 8.1.27
Python    | 3.9.2
Database  | MariaDB 10.5.23-MariaDB-0+deb11u1
SNMP      | 5.9
[OK]    Composer Version: 2.7.7
[WARN]  Your database schema has extra migrations (2023_11_27_163400_increase_syslog_fields). If you just switched to the stable release from the daily release, your database is in between releases and this will be resolved with the next release.
[OK]    Python wrapper cron entry is not present
[OK]    Redis is functional
Thank you for any hints!
