After the daily update one or two nights ago I noticed my API authentication is now broken. You can see in the attached screenshot the API keys are no longer associated with a user. When I try and make an API call such as https://libre-server/api/v0/oxidized I get the below error:
}[root@librenms]# curl http:/libre-server/api/v0/oxidized -H ‘X-Auth-Token: ’
“status”: “error”,
“message”: “API Token is missing or invalid; please supply a valid token”
This is working properly in the stable release.
- The output of
./validate.php
Component | Version |
LibreNMS | 1.42.01-59-g4158615 |
DB Schema | 260 |
PHP | 7.2.5 |
MySQL | 10.1.31-MariaDB |
RRDTool | 1.6.0 |
SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.7.2
[OK] Database schema correct![27%20PM|690x150]
