I was trying to add a cusom OID to one of my devices. When I attempted to add it the tests were failing. The failed tests resulted in a librenms.log entry of:
[datetime][ERROR] snmp_get called for multiple OIDs: ### {"userId":5,"exception":"[object] (Exception(code: 0): snmp_get called for multiple OIDs: ### at /opt/librenms/includes/snmp.inc.php:286)"}
Where ### was the OID digits. The odd thing was it only listed the single OID that I had given it, not multiples.
After some poking around I found something that looked odd in the file ~/includes/html/forms/customoid.inc.php where line line 16 read:
$id = $_POST['ccustomoid_id'];
The string customoid_id appeared elsewhere in the file, but ccustomoid_id did not. I edited the file to remove what appeared to be a spuriuos c and lo! my tests are now successful.
I didn’t think I’d been in this file before to screw it up, so I checked Github (https://github.com/librenms/librenms/blob/master/includes/html/forms/customoid.inc.php) and found the same spelling here.
I’ve got no idea what I’m doing, but removing one little letter from a file cause a failure to become a success, so I thought I would report it here just in case.
Of course, validation failed after I did this.
~$ ./validate.php
LibreNMS | 25.2.0-18-g4cfd5a886 (2025-02-28T03:09:23-06:00)
DB Schema | 2025_01_20_125000_create_ospfv3_ports_table (319)
PHP | 8.3.14
Python | 3.8.10
Database | MariaDB 10.3.39-MariaDB-0ubuntu0.20.04.2
RRDTool | 1.7.2
SNMP | 5.8
[OK] Composer Version: 2.8.6
Modified Files:
