Possible to adjust/increase SSH timeout?
We have some slower palo alto pa-220 firewalls that we recently upgraded to 8.1.0 for bleeding edge fun. For some reason now, on this new version, it takes 8-10 seconds before getting a response to an SSH connection. I’ve talked to Palo Alto support and they say that this is expected behavior, which seems wrong but whatever…
Anyway, is there a way to increase the SSH timeout on Oxidized? I see the “timeout” setting, but that is for the configuration to be pulled down…right?
Thanks!
Josh
Yes,
you can set the timeout parameter in your oxidized config:
timeout: 120
retries: 3
cheers
