Possible to hide devices in matainence from showing up in map?
I have read that libreNMS polls devices even when they are in maintenance. Is there any way to keep them from showing up in the outage map?
I know I can simply set the map to only show up devices but I don’t want to do that.
Thanks in advance.
You can’t hide devices from the maps. That require code changes. Code changes are welcomed :slight_smile:
