So, I am back after a longer pause. I have librenms running in VM under KVM, and I have been able to add three devices, a mikrotik router, a QNAP NAS and a raspi pi-hole. All well so far, and they report back all SNMP stats correctly. I installed libreNMS from a prebuilt VMDK file, and converted to QCOW2 so I did not installs the packages myself.
I have two problems that I cant find any obvious solutions to.
- Dashboard. The widget dropdown is empty.
- Modules. When I edit the properties for any of the devices, and clicks on the Modules tab, I get a new tab with a blank webpage saying 404 - Not found. Nothing else. Browser is MS Edge on Ubuntu (not the VM, from the host).
Grateful for any pointers to where I should look.
librenms@librenms:~$ php /opt/librenms/validate.php
| LibreNMS | 21.2.0-2-gd20e1bdf5 |
| DB Schema | 2021_02_09_084318_remove_perf_times (199) |
| PHP | 7.4.3 |
| Python | 3.8.5 |
| MySQL | 10.3.25-MariaDB-0ubuntu0.20.04.1 |
| RRDTool | 1.7.2 |
| SNMP | NET-SNMP 5.8 |
[OK] Composer Version: 2.1.8
[WARN] Your install is over 24 hours out of date, last update: Thu, 18 Feb 2021 14:10:32 +0000
librenms@librenms:~$ bash daily.sh
Updating Composer packages OK
Updated from d20e1bdf5 to 59859c2ea OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
Caching Mac OUI data OK
Edit: The widgets are working now after running the daily.sh script! Device/Modules still shows a 404 page.
Edit 2: Modules also working now. The default global setting for Web UI contained “http:/” and that was my problem. Removed that and now it the modules page works as it should.
