TL;DR - After running the recommended file permissions commands for the 1.44 pre-checks, validate.php generated a number of git warnings concerning modified files.
This is an existing, working install running on CentOS7 with nginx. This is the output from validate.php prior to running the recommended pre-checks for 1.44:
LibreNMS | 1.43
DB Schema | 262
PHP | 7.2.8
MySQL | 5.5.56-MariaDB
RRDTool | 1.4.8
SNMP | NET-SNMP 5.7.2
[OK] Composer Version: 1.7.2
I then applied the recommended chown/setfacl/chmod commands and re-ran validate.php. I then got this:
LibreNMS | 1.43
DB Schema | 262
PHP | 7.2.8
RRDTool | 1.4.8
Modified Files:
bootstrap/cache/.gitignore
logs/.gitignore
rrd/.gitignore
storage/app/.gitignore
storage/app/public/.gitignore
storage/debugbar/.gitignore
storage/logs/.gitignore
I did consider running github-remove but that suggested it would end up deleting all these .gitignore files which is not something I’m sure would be a good thing (although I’m no git expert).
Is it safe to run github-remove or is there a better way of fixing this?
Thanks,
Matthew.
