Hi, I upgraded to the latest PHP a few days ago (PHP 7.2.15-1+ubuntu16.04.1+deb.sury.org+1) and since then when I try to go to the LibreNMS web page I get a 500 error.
./daily.php and ./validate.php return ok:
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
and
| LibreNMS | 1.48.1-62-gfcb0b67 |
| DB Schema | 2019_01_16_195644_add_vrf_id_and_bgpLocalAs (131) |
| PHP | 7.2.15-1+ubuntu16.04.1+deb.sury.org+1 |
| MySQL | 10.0.38-MariaDB-0ubuntu0.16.04.1 |
| RRDTool | 1.5.5 |
| SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.8.4
Librenms.log is not reporting errors, but I do see these errors in error.log:
2019/02/16 09:47:43 [error] 1051#1051: *12 FastCGI sent in stderr: “PHP message: PHP Parse error: syntax error, unexpected ‘=’ in /opt/librenms/vendor/laravel/framework/src/Illuminate/Support/Arr.php on line 388” while reading response header from upstream, client: 192.168.1.92, server: librenms.example.com, request: “GET / HTTP/1.1”, upstream: “fastcgi://unix:/var/run/php/php7.0-fpm.sock:”, host: “librenms”
Any ideas?
