I’m looking for a bit of advice. I have LibreNMS set up and running on a small server. I also have a valid SSL certificate set up on it too. The server sits inside my network on a private IP address (let’s call it 192.168.1.1).
So to access the server from inside the network, I’m using https://192.168.1.1 - this works just fine bound to port 443.
However, I’d like to punch a port forwarding setup from my router to the server to allow me to access it via the Internet. When I do that, and try to access it via https://server.foobar.com:8443 I get a bunch of browser access warnings
[Error] Unhandled Promise Rejection: SecurityError: Script origin does not match the registering client’s origin
[Error] Origin https://server.foobar.com:8443 is not allowed by Access-Control-Allow-Origin.
[Error] XMLHttpRequest cannot load https://server.foobar.com/ajax_form.php due to access control checks.
Okay - so this sounds like I need to enable CORS to allow access. However, I can’t seem to get this to work at all. The $config[] examples for CORS all seem applicable to API access from external hosts (and don’t help me here when configured)
I’ve had a look at and tweaked config/cors.php to enable CORS there for this
‘allowed_origins’ => [’*’],
but that doesn’t seem to help either.
So to recap - I want to be able to access LibreNMS from https://192.168.1.1 and https://server.foobar.com:8443 but can’t get the latter option to work. Help? Anyone done this and can offer words of wisdom as to how I get LibreNMS to generate the right CORS preflight response for me?
Thanks!
Scott…
I managed to wipe the base_url setting out and that fixed the problem. Thanks!
