i have a serious problem with Alerting system.
For example, if i create a test rule (see image)
IF LibreNMS find a machine with hostname equals to “pensiero” ( and i have a machine with this name ) the alerting system will be triggered, right?
And it is so, i receive the first Altert after 8 Minutes ( not 5m )
After this, I should receive the same alert every 10 minutes - infinite times (-1), until status change, right?.
but it does not happen, why?
(i receive only the first CRITICAL alert but nothing more after that)
Please help me to troubleshoot that
Thank you very much
–INFO–
“Monitor” is based on a “Raspberry Pi 2” with Raspbian (Debian)
config.php
<?php
Have a look in includes/defaults.inc.php for examples of settings you can set here. DO NOT EDIT defaults.inc.php!
Database config
$config[‘db_host’] = ‘localhost’;
$config[‘db_user’] = ‘root’;
$config[‘db_pass’] = ‘ohdoishdodhsa87’;
$config[‘db_name’] = ‘librenms’;
// This is the user LibreNMS will run as
//Please ensure this user is created and has the correct permissions to your install
$config[‘user’] = ‘librenms’;
This should only be set if you want to force a particular hostname/port
It will prevent the web interface being usable form any other hostname
$config[‘base_url’] = “/”;
Enable this to use rrdcached. Be sure rrd_dir is within the rrdcached dir
and that your web server has permission to talk to rrdcached.
#$config[‘rrdcached’] = “unix:/var/run/rrdcached.sock”;
Default community
$config[‘snmp’][‘community’] = array(“public”);
Authentication Model
$config[‘auth_mechanism’] = “mysql”; # default, other options: ldap, http-auth
#$config[‘http_auth_guest’] = “guest”; # remember to configure this user if you use http-auth
List of RFC1918 networks to allow scanning-based discovery
#$config[‘nets’] = “10.0.0.0/8”;
#$config[‘nets’] = “172.16.0.0/12”;
#$config[‘nets’] = “192.168.0.0/16”;
Uncomment the next line to disable daily updates
#$config[‘update’] = 0;
Number in days of how long to keep old rrd files. 0 disables this feature
#$config[‘rrd_purge’] = 0;
Uncomment to submit callback stats via proxy
#$config[‘callback_proxy’] = “hostname:port”;
Set default port association mode for new devices (default: ifIndex)
#$config[‘default_port_association_mode’] = ‘ifIndex’;
Enable the in-built billing extension
$config[‘enable_billing’] = 1;
Enable the in-built services support (Nagios plugins)
$config[‘show_services’] = 1;
validate.php output
librenms@Monitor:~$ ./validate.php
Component Version LibreNMS 06add776858ff19e24c08ad0e53a1c3bf795fe1a DB Schema 185 PHP 5.6.29-0+deb8u1 MySQL 10.0.30-MariaDB-0+deb8u1 RRDTool 1.4.8 SNMP NET-SNMP 5.7.2.1 ==========================================================
librenms@Monitor:~$
cron status
librenms@Monitor:~$ service cron status
● cron.service - Regular background program processing daemon
Loaded: loaded (/lib/systemd/system/cron.service; enabled)
Active: active (running) since Tue 2017-04-11 11:57:16 CEST; 2 days ago
Docs: man:cron(8)
Main PID: 493 (cron)
CGroup: /system.slice/cron.service
├─493 /usr/sbin/cron -f
├─511 sudo sh /home/pi/vpn.sh
├─547 sh /home/pi/vpn.sh
├─557 sudo openvpn --config pensiero.servizi-web.net.conf
└─573 openvpn --config pensiero.servizi-web.net.conf
librenms@Monitor:~$
cron file
librenms@Monitor:~$ cat /etc/cron.d/librenms
Using this cron file requires an additional user on your system, please see install docs.
33 */6 * * * librenms /opt/librenms/discovery.php -h all >> /dev/null 2>&1
15 0 * * * librenms /opt/librenms/daily.sh >> /dev/null 2>&1
- librenms /opt/librenms/alerts.php >> /dev/null 2>&1
librenms@Monitor:~$
