"Problem with backend" in dashboard Availability map
Hello, I have a display problem. Problem with backend in dashboard “Availability map”
librenms is installed on a debian 12.1
LibreNMS 23.8.2-27-gd991a4b50 (2023-09-05T23:08:15+02:00)
DB Schema 2023_09_01_084057_application_new_defaults (258)
PHP 8.1.22
Python 3.11.2
Database MariaDB 10.11.3-MariaDB-1
SNMP 5.9.3
[OK] Composer Version: 2.6.2
[OK] MySQl and PHP time match
librenms@librenms:~$
librenms@librenms:~$ ./daily.sh
Updating Composer packages OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
I rebooted the server without resolving the problem
I have the same problem, running Debian 12 as well.
I think there was an upgrade of the php packages just a couple of days ago (maybe even yesterday).
I am absolutely certain the timezone is set correctly in both php ini files. I’ve run LibreNMS without issue for a long time.
I had the same issue and just find out what was the problem.
In the settings of the Availability map widget, set the Disabled polling/alerting to Hide instead of Show :
And Voilà
Looks like someone broke it, should be fixed next update (or run ./daily.sh)
