We’re having some issues with 1 of our Juniper QFX switches in regards to TX power. The SFPs in question are used to connect 2 pairs of devices connected together over multiple channels and although they are the same SFP brand and similar channels for all 4 switches, for some reason, it’s complaining about sensor over limit for one of the 4 devices.
I was curious to know how it actually picked up the sensor thresholds? Does it get them from the SNMP values of jnxDomCurrentTxLaserOutputPowerHighWarningThreshold (.1.3.6.1.4.1.2636.3.60.1.1.1.1.19) during device discovery? I ask because the dbm values are similar on all 4 devices and when comparing the SNMP values, it falls well below the Warning threshold, which itself is below the alarm threshold. Also, when querying for jnxDomCurrentAlarms, no alarms are active for the device.
Here’s an alarm for one of the ports:
#1: sensor_id => '1327', sensor_oid => '.1.3.6.1.4.1.2636.3.60.1.1.1.1.7.520', sensor_descr => 'xe-0/0/21 Tx Power', sysObjectID => 'enterprises.2636.1.1.1.4.82.5', sysDescr => 'Juniper Networks, Inc. qfx5100-48s-6q Ethernet Switch, kernel JUNOS 14.1X53-D42.3, Build date: 2017-02-14 20:16:27 UTC Copyright (c) 1996-2017 Juniper Networks, Inc.'
Here’s an output of the SNMP queries for that port:
jnxDomCurrentTxLaserOutputPower: SNMPv2-SMI::enterprises.2636.3.60.1.1.1.1.7.520 = INTEGER: 200 jnxDomCurrentTxLaserOutputPowerHighWarningThreshold: SNMPv2-SMI::enterprises.2636.3.60.1.1.1.1.19.520 = INTEGER: 600 jnxDomCurrentTxLaserOutputPowerLowWarningThreshold: SNMPv2-SMI::enterprises.2636.3.60.1.1.1.1.20.520 = INTEGER: -199 jnxDomCurrentTxLaserOutputPowerHighAlarmThreshold: SNMPv2-SMI::enterprises.2636.3.60.1.1.1.1.17.520 = INTEGER: 700 jnxDomCurrentTxLaserOutputPowerLowAlarmThreshold: SNMPv2-SMI::enterprises.2636.3.60.1.1.1.1.18.520 = INTEGER: -300
Any clue as to why we would have 9 such alarms for one host? I’ve tried re-discovering the device without any result and even deleting/adding the device.
Thanks!
