Hi
today I all of a sudden have problems with front page not containing global map.
when i look in the logs (/opt/librenms/logs/error.log). I see the following errors:
AH01276: Cannot serve directory /opt/librenms/html/js/maps/: No matching DirectoryIndex (index.html,index.cgi,index.pl,index.php,index.xhtml,index.htm) found, and server-generated directory index forbidden by Options directive
Component | Version |
LibreNMS | 6a79d4495f1a5d91d476021b7fb3ab58889e6f80 |
DB Schema | 192 |
PHP | 7.0.15-0ubuntu0.16.04.4 |
MySQL | 5.7.18-0ubuntu0.16.04.1 |
RRDTool | 1.5.5 |
SNMP | NET-SNMP 5.7.3 |
[WARN] Your install is out of date, last update: Sun, 28 May 2017 21:54:20 +0000
Thanks for a fantastic system.
