I install librenms on VM
after i finish to install itryd to get in web
and i get it without graphics
what to do?
what to do?
Make sure your server_name is set correctly in your nginx/apache config. If you don’t have a real hostname, use the IP for server_name.
did you restart your http server after changing it? What does ./validate.php show?
That depends on your distribution/http server. Could be service whatever restart, where whatever could be nginx, apache, apache24, etc.
I did to nginx a restart but steel the same
Did you fix the timezone problem in the php .ini file ?
If not follow the link then rerun validate.
