I have common “compose” setup
all starts fine but after some time(24h) dispatcher stops polling - At this point i see in web Ui at /polling that
“Device Actioned Last interval” is 0.
Started checking logs. And i see next exceptions which repeats over time:
[2021-01-20 02:12:13] production.ERROR: Cannot unset string offsets {“exception”:"[object] (Error(code: 0): Cannot unset string offsets at /opt/librenms/includes/discovery/route.inc.php:265)
[stacktrace]
#0 /opt/librenms/includes/discovery/functions.inc.php(165): include()
#1 /opt/librenms/discovery.php(116): discover_device(Array, false)
#2 {main}
I checked this line:
Its smth about mpls discovery. I disabled mpls discovery_module and restarted. But exceptions appear again.
Noob in php, so need your help with this issue.
Validate:
bash-5.0# ./validate.php
LibreNMS | 1.69
DB Schema | 2020_10_21_124101_allow_nullable_ospf_columns (188)
PHP | 7.3.24
Python | 3.8.5
MySQL | 10.4.16-MariaDB-1:10.4.16+maria~focal
RRDTool | 1.7.2
SNMP | NET-SNMP 5.8
OpenSSL |
Configuration
- Docker version 18.09.2, build 6247962
- docker-compose version 1.18.0, build 8dd22a9
- Platform Centos 7.
- Virtualization: vmware
- Linux 3.10.0-957.5.1.el7.x86_64
If i check inside container when in fault state:
And after execution of the command “docker restart librenms_dispatcher” all backs to normal for some time and inside container i see a lot of monitoring processes
