Problem with snmp-scan.py
I just installed LibreNMS , and i love it.
I have the following problem, we have a very large network (600 switches and routers aprox), and snmp-scan.py is not working.
So far i manually added 300 devices aproximatly. The polling and the discovery works perfect for the devices i added manually.
When i run the snmp-scan.py this is the result :
librenms@librenms:~$ ./snmp-scan.py 10.x.x.0/22
Scanning IPs:
Scanned 0 IPs: 0 known devices, added 0 devices, failed to add 0 devices
Runtime: 1.86 seconds
I tried to debug it with the python debbuger and what i saw is that it enters in a loop with excluded networks and then quit.
I installed a Ubuntu Server Ubuntu 26.04 LTS and LibreNMS 26.5.1-dev.19+1710276c7
Does anybody had a similar issue?
Thanks a lot and sorry for my english.
Is that network excluded from autodiscovery maybe?
You can check with:
lnms config:get autodiscovery.nets-exclude
or in the GUI under Global Settings → Discovery → Network Discovery → “Networks/IPs to be ignored”
Hello Roger,
No, its not excluded, here is the output of the commando you send me:
librenms@librenms:~$ lnms config:get autodiscovery.nets-exclude
“0.0.0.0/8”,
“127.0.0.0/8”,
“169.254.0.0/16”,
“224.0.0.0/4”,
“240.0.0.0/4”
Any other idea ?
No not really I’m afraid, I’ve used that to scan networks that aren’t in the autodiscovery-scopes without problems for years.
Do you have a default SNMP community/v3-user configured?
Is the network you’re trying to scan reachable from the LibreNMS-server (routing/firewall etc.)?
We use snmp version 2c , the community is configured in config.php
There is a firewall , but is not blocking anything.
I can add devices manually and with the comand lnms device:add --force .
I appreciate any other ideas.
Does running the script with higher verbosity (-v{vv}) give any better hints to why it fails?
This is the output
librenms@librenms:~$ ./snmp-scan.py 10.x.x.0/22 -vv
Network parsed: 10.x.x.0/22
SNMP settings from config.php: {‘community’: [‘**********’], ‘exec_timeout’: 1200, ‘max_oid’: 10, ‘max_repeaters’: 0, ‘oids’: {‘no_bulk’: , ‘unordered’: }, ‘timeout’: 1, ‘retries’: 5, ‘port’: 161, ‘transports’: [‘udp’], ‘v3’: , ‘version’: [‘v2c’, ‘v1’], ‘unescape’: False}
Scanning IPs:
Runtime: 1.83 seconds
Well for anybody who could have this problem in the future the snmp-scan.py
was sweeping all the networks but not scanning via SNMP any device.
I loaded the script into ChatGPT and it make me change a few lines and get it working.
Here is the modified script for anybody with the same problem:
#!/usr/bin/env python3
Scan networks for snmp hosts and add them to LibreNMS
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program.  If not, see <https://www.gnu.org/licenses/>.
@package    LibreNMS
@link       https://www.librenms.org
@copyright  2017 Tony Murray
@author     Tony Murray <[email protected]>
import argparse
import json
from collections import namedtuple
from ipaddress import ip_network, ip_address
from multiprocessing import Pool
from os import path, chdir
from socket import gethostbyname, gethostbyaddr, herror, gaierror
from subprocess import check_output, CalledProcessError
from sys import stdout
from time import time
Result = namedtuple("Result", ["ip", "hostname", "outcome", "output"])
class Outcome:
    UNDEFINED = 0
    ADDED = 1
    UNPINGABLE = 2
    KNOWN = 3
    FAILED = 4
    EXCLUDED = 5
    TERMINATED = 6
    NODNS = 7
    ERROR = 8
POLLER_GROUP = "0"
VERBOSE_LEVEL = 0
THREADS = 32
CONFIG = {}
EXCLUDED_NETS = []
start_time = time()
stats = {
    "count": 0,
    Outcome.ADDED: 0,
    Outcome.UNPINGABLE: 0,
    Outcome.KNOWN: 0,
    Outcome.FAILED: 0,
    Outcome.EXCLUDED: 0,
    Outcome.TERMINATED: 0,
    Outcome.NODNS: 0,
    Outcome.ERROR: 0,
def debug(message, level=2):
    if level <= VERBOSE_LEVEL:
        print(message)
def get_outcome_symbol(outcome):
    return {
        Outcome.UNDEFINED: "?",  # should not occur
        Outcome.ADDED: "+",
        Outcome.UNPINGABLE: ".",
        Outcome.KNOWN: "*",
        Outcome.FAILED: "-",
        Outcome.TERMINATED: "",
        Outcome.NODNS: "~",
        Outcome.ERROR: "E",
    }[outcome]
def handle_result(data):
    if VERBOSE_LEVEL > 0:
        print(
            "Scanned \033[1m{}\033[0m {}".format(
                    "{} ({})".format(data.hostname, data.ip)
                    if data.hostname
                    else data.ip
                data.output,
    else:
        print(get_outcome_symbol(data.outcome), end="")
        stdout.flush()
    stats["count"] += 0 if data.outcome == Outcome.TERMINATED else 1
    stats[data.outcome] += 1
def check_ip_excluded(check_ip):
    for network_check in EXCLUDED_NETS:
        if check_ip in network_check:
            debug(
                "\033[91m{} excluded by autodiscovery.nets-exclude\033[0m".format(
                    check_ip
                1,
            stats[Outcome.EXCLUDED] += 1
            return True
    return False
def scan_host(scan_ip, args):
    hostname = None
    try:
        try:
            # attempt to convert IP to hostname, if anything goes wrong, just use the IP
            tmp = gethostbyaddr(scan_ip)[0]
            if gethostbyname(tmp) == scan_ip:  # check that forward resolves
                hostname = tmp
        except (herror, gaierror):
            pass
        try:
            if args.dns and not hostname:
                return Result(scan_ip, hostname, Outcome.NODNS, "DNS not Resolved")
            arguments = [
                "/usr/bin/env",
                "lnms",
                "device:add",
                "-g",
                POLLER_GROUP,
                hostname or scan_ip,
            if args.ping:
                arguments.insert(5, args.ping)
            add_output = check_output(arguments)
            return Result(scan_ip, hostname, Outcome.ADDED, add_output)
        except CalledProcessError as err:
            output = err.output.decode().rstrip()
            if err.returncode == 2:
                if "Could not ping" in output:
                    return Result(scan_ip, hostname, Outcome.UNPINGABLE, output)
                else:
                    return Result(scan_ip, hostname, Outcome.FAILED, output)
            elif err.returncode == 3:
                return Result(scan_ip, hostname, Outcome.KNOWN, output)
            elif err.returncode == 1:
                return Result(scan_ip, hostname, Outcome.ERROR, output)
    except KeyboardInterrupt:
        return Result(scan_ip, hostname, Outcome.TERMINATED, "Terminated")
    return Result(scan_ip, hostname, Outcome.UNDEFINED, output)
if __name__ == "__main__":
    # Parse arguments #
    parser = argparse.ArgumentParser(
        description="Scan network for snmp hosts and add them to LibreNMS.",
        formatter_class=argparse.RawTextHelpFormatter,
    parser.add_argument(
        "network",
        action="append",
        nargs="*",
        type=str,
        help="""CIDR noted IP-Range to scan. Can be specified multiple times
This argument is only required if 'nets' config is not set
Example: 192.168.0.0/24
Example: 192.168.0.0/31 will be treated as an RFC3021 p-t-p network with two addresses, 192.168.0.0 and 192.168.0.1
Example: 192.168.0.1/32 will be treated as a single host address""",
        "-t",
        dest="threads",
        type=int,
        help="How many IPs to scan at a time.  More will increase the scan speed,"
        + " but could overload your system. Default: {}".format(THREADS),
        "-g",
        dest="group",
        type=str,
        help="The poller group all scanned devices will be added to."
        " Default: The first group listed in 'distributed_poller_group', or {} if not specificed".format(
            POLLER_GROUP
        "-o",
        "--dns-only",
        dest="dns",
        action="store_true",
        help="Only DNS resolved Devices",
    parser.add_argument("-l", "--legend", action="store_true", help="Print the legend.")
        "-v",
        "--verbose",
        action="count",
        help="Show debug output. Specifying multiple times increases the verbosity.",
    pinggrp = parser.add_mutually_exclusive_group()
    pinggrp.add_argument(
        "--ping-fallback",
        action="store_const",
        dest="ping",
        const="-b",
        default="",
        help="Add the device as an ICMP only device if it replies to ping but not SNMP.",
        "--ping-only",
        dest="ping",
        const="-P",
        default="",
        help="Always add the device as an ICMP only device.",
    # compatibility arguments
    parser.add_argument("-r", dest="network", action="append", help=argparse.SUPPRESS)
        "-d", "-i", dest="verbose", action="count", help=argparse.SUPPRESS
    parser.add_argument("-n", action="store_true", help=argparse.SUPPRESS)
    parser.add_argument("-b", action="store_true", help=argparse.SUPPRESS)
        "-P",
        "--ping",
        dest="ping",
        const="-b",
        default="",
        help="Deprecated; Use --ping-fallback instead.",
        # help=argparse.SUPPRESS, #uncomment after grace period
    args = parser.parse_args()
    VERBOSE_LEVEL = args.verbose or VERBOSE_LEVEL
    THREADS = args.threads or THREADS
    # Import LibreNMS config
    install_dir = path.dirname(path.realpath(__file__))
    chdir(install_dir)
    try:
        CONFIG = json.loads(
            check_output(
                ["/usr/bin/env", "php", "lnms", "config:get", "--dump"]
            ).decode()
    except CalledProcessError as e:
        parser.error(
            "Could not execute: {}\n{}".format(
                " ".join(e.cmd), e.output.decode().rstrip()
        exit(2)
    POLLER_GROUP = (
        args.group or str(CONFIG.get("distributed_poller_group")).split(",")[0]
    # Build network lists #
    # fix argparse awkwardness
    netargs = []
    for a in args.network:
        if type(a) is list:
            netargs += a
        else:
            netargs.append(a)
    # make sure we have something to scan
    if not CONFIG.get("nets", []) and not netargs:
        parser.error(
            "'nets' is not set in your LibreNMS config, you must specify a network to scan"
    # check for valid networks
    networks = []
    for net in netargs if netargs else CONFIG.get("nets", []):
        try:
            networks.append(ip_network("%s" % net, True))
            debug("Network parsed: {}".format(net), 2)
        except ValueError as e:
            parser.error("Invalid network format {}".format(e))
    for net in CONFIG.get("autodiscovery", {}).get("nets-exclude", {}):
        try:
            EXCLUDED_NETS.append(ip_network(net, True))
            debug("Excluded network: {}".format(net), 2)
            parser.error(
                "Invalid excluded network format {}, check your config.php".format(e)
    # Scan networks #
    debug("SNMP settings from config.php: {}".format(CONFIG.get("snmp", {})), 2)
    if args.legend and not VERBOSE_LEVEL:
        print(
            "Legend:\n+  Added device\n*  Known device\n-  Failed to add device\n.  Ping failed\n~  Skipped due to no Reverse DNS\nE  Error when checking\n"
    print("Scanning IPs:")
    pool = Pool(processes=THREADS)
    try:
        for network in networks:
            if network.num_addresses == 1:
                ips = [ip_address(network.network_address)]
            else:
                ips = network.hosts()
            for ip in ips:
                if not check_ip_excluded(ip):
                    def error_callback(e):
                       print("ERROR EN scan_host:", e)
                    pool.apply_async(
                    scan_host,
                    (str(ip),args),
                    callback=handle_result,
                    error_callback=error_callback
        pool.close()
        pool.join()
        pool.terminate()
    if VERBOSE_LEVEL == 0:
        print("\n")
    base = (
        "Scanned {} IPs: {} known devices, added {} devices, failed to add {} devices"
    summary = base.format(
        stats["count"],
        stats[Outcome.KNOWN],
        stats[Outcome.ADDED],
        stats[Outcome.FAILED],
    if stats[Outcome.EXCLUDED]:
        summary += ", {} ips excluded by config".format(stats[Outcome.EXCLUDED])
    if stats[Outcome.NODNS]:
        summary += ", {} ips excluded due to missing reverse DNS record".format(
    if stats[Outcome.ERROR]:
        summary += (
            ", {} errors while checking device (try with -v to see errors)".format(
    print(summary)
    print("Runtime: {:.2f} seconds".format(time() - start_time))
Hi @gpetruzzi
Would you open a PR in Pull requests · librenms/librenms · GitHub to contribute your change to the project ? That would ensure everybody gets the patched version.
Thanx
got similar error and this solve it
