Starting this week the validate.php script says:
| LibreNMS | 1.48.1-85-gee76057 |
| DB Schema | 2019_02_10_220000_add_dates_to_fdb (132) |
| PHP | 7.2.15-1+ubuntu16.04.1+deb.sury.org+1 |
| MySQL | 10.0.38-MariaDB-0ubuntu0.16.04.1 |
| RRDTool | 1.5.5 |
| SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.6.3
[FAIL] fping could not be executed. fping must have CAP_NET_RAW capability (getcap) or suid. Selinux exlusions may be required.
[FAIL] fping6 could not be executed. fping6 must have CAP_NET_RAW capability (getcap) or suid. Selinux exlusions may be required.
The setup is online since last year and never had this problem.
fping and fping6 are present in the system (Ubuntu 16.04). Caps are ok.
# getcap /usr/bin/fping*
/usr/bin/fping = cap_net_raw+ep
/usr/bin/fping6 = cap_net_raw+ep
# fping -v
fping: Version 3.13
fping: comments to [email protected]
# fping6 -v
fping: Version 3.13
Read the threads about it with no solutions, tried to add the path in config.php and nothing changed.
fping runs as librenms user with no problems:
# sudo -u librenms fping 10.136.12.1
10.136.12.1 is alive
Any ideas?
