(just looked - librenms uses 0.97c. These are the changes since then:
0.98a
FIXED - Works with PHP 7.x and 5.6 - removed all mysql_*() function calls, and use PDO instead
FIXED - Blank line issue with RRDtool 1.5+
0.98
FIXED - MySQL error in table-creation. MySQL 5.6 is fussier.
FIXED - Editor 'delete link' broken
FIXED - KILO was ignored when processing %k in special tokens
FIXED - Various fixes for PHP deprecated or strict-mode warnings
FIXED - Line-ending trimming in 'external script' data source
FIXED - rounding error 'kinks' in angled VIA links
FIXED - Config file path validation issue in editor (CVE-2013-3739)
FIXED - Cloning a templated node in editor retains the template in the clone
FIXED - cacti_use_ifspeed incorrect when interfaces > 20M and ifhighspeed available
FIXED - More PHP 5.3/5.4/strict related errors (split -> explode)
CHANGE - Finally switch to "new-style" plugin API.
CHANGE - Editor data picker improved sort (thanks shd)
CHANGE - (Cacti plugin only) images are written to a temporary file first, to avoid displaying half-written images
CHANGE - Editor no longer uses editor-config.php
ADDED - Weathermap will use anti-aliasing if your GD supports it (php-bundled GD doesn't) (thanks shd)
ADDED - Special token formatting can handle timeticks and time_t formatting (%T and %t respectively)
ADDED - new DATAOUTPUTFILE allows collected data to be written to a file for later use (automatically enabled in Cacti)
ADDED - new wmdata: datasource plugin can read data from files produced by DATAOUTPUTFILE
ADDED - IMAGEOUTPUTFILE and HTMLOUTPUTFILE are honoured in Cacti poller as a location for a second copy of those files.
ADDED - Editor 'tidy link' function replaces Vert & Horiz, and does much nicer job
ADDED - 'retidy' option in editor to recalculate all links previously positioned with 'tidy'.
ADDED - KEYBGCOLOR and KEYOUTLINECOLOR both accept 'none'
ADDED - command-line weathermap has new --no-warn option to disable warnings
ADDED - AICONFILLCOLOR accepts 'none' for drawing giant transparent shapes.
ADDED - Extra warning for Boost users about poller_output
ADDED - if there are actually 0 maps in the database, the 'Weathermaps' tab gives some basic instructions.
ADDED - Cacti data picker in editor tracks most recently used hosts (thanks Zdolny)
ADDED - New permission in Cacti: edit maps. Maps can be edited by authorized users without needing to enable the editor in the source code.
