Hi All,
I recently installed LibreNMS with Apache on Lubuntu 18.04. After finishing up the installation, my validate config told me that
`You can fix this with ./scripts/github-remove
When I tried it at terminal
admin2@LibreNMSST:~$ sudo ./scripts/github-remove
[sudo] password for admin2:
sudo: ./scripts/github-remove: command not found
What should I concern to solve it?
This is the message.
Updates Warning
Warning: Your local git contains modified files, this could prevent automatic updates.
Fix:
Modified Files
bootstrap/cache/.gitignore
logs/.gitignore
rrd/.gitignore
storage/app/.gitignore
storage/app/public/.gitignore
storage/debugbar/.gitignore
Chas
28 August 2019 10:05
3
su librenms -
/opt/librenms/scripts/github-remove -d
(Update fails due to .gitignore files )
The issue has been solved. Thanks!
