Hello I need help please.
After update I have some problems.
root@6b6c22e3fc77:/opt/librenms# ./scripts/composer_wrapper.php install --no-dev> LibreNMS\ComposerHelper::preInstall
Verifying lock file contents can be installed on current platform.
Package operations: 56 installs, 11 updates, 3 removals
- Downloading wpb/string-blade-compiler (3.8.x-dev b3e340b)
0/1 [>---------------------------] 0% Failed to download wpb/string-blade-compiler from dist: The “https://api.github.com/repos/librenms/StringBladeCompiler/zipball/b3e340b79e99f92a0d40adaba0dd9f2b533fc65b” file could not be downloaded (HTTP/2 404 ):
{“message”:“Not Found”,“documentation_url”:“Repositories - GitHub Docs”}
Now trying to download from source - Syncing wpb/string-blade-compiler (3.8.x-dev b3e340b) into cache
Cloning failed using an ssh key for authentication, enter your GitHub credentials to access private repos
Note that such tokens have broad read/write permissions on your behalf, even if not needed by Composer.
Tokens will be stored in plain text in “/root/.composer/auth.json” for future use by Composer.
For additional information, check Authentication for privately hosted packages and repositories - Composer
Token (hidden):
Thanks for your help.
