We have in our organization a LibreNMS that polls 2500 devices and the idea is that it reaches 4000. But although it has many resources, the poller is already more than half an hour, so we have implemented an additional machine to help the main server.
First of all, I have followed all the documentation of Install LibreNMS, Dispatcher Service and Distributed Poller.
WebServer (IP: X.X.X.13):
librenms@librenms-com:~$ ./validate.php
| LibreNMS | 25.3.0-19-g3e4b8c5a2 (2025-03-20T02:02:41+01:00) |
| DB Schema | 2025_03_11_031114_drop_ospfv3ifinstid (321) |
| PHP | 8.3.19 |
| Python | 3.11.2 |
| Database | MariaDB 10.11.11-MariaDB-0+deb12u1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.3 |
[OK] Composer Version: 2.8.6
[FAIL] Some dispatcher nodes have not checked in recently
Inactive Nodes:
librenms-poller
[OK] Redis is functional
[FAIL] Python3 module issue found: 'Required packages: [‘PyMySQL!=1.0.0’, ‘python-dotenv’, ‘redis>=4.0’, ‘setuptools’, ‘psutil>=5.6.0’, ‘command_runner>=1.3.0’]
Package not found: The ‘command_runner>=1.3.0’ distribution was not found and is required by the application
pip3 install -r /opt/librenms/requirements.txt
And Server2 (service librenms stop. IP: X.X.X.19):
librenms@librenms-poller:~$ ./validate.php
| PHP | 8.2.28 |
| Python | 3.11.2 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.3 |
Inactive Nodes:
librenms-poller (this node)
Output .env webserver:
librenms@librenms-com:~$ cat .env
APP_KEY=base64:bC568SVDdMnq5I4tpxNIaLjIo6LT5SKQEvw6JhzrNPQ=
DB_HOST=localhost
DB_DATABASE=librenms
DB_USERNAME=librenms
DB_PASSWORD=password
APP_URL=https://librenms-com.domain.es
NODE_ID=6399c4b270877
VAPID_PUBLIC_KEY=BFPSn6DUdTgBqRHNDVRbJlFCHNv01jKOjhDB67oEkCIkzi-_zu7P5jAYNTtaUZwOkoAy_y1nbMgseDi3UKkYXBU
VAPID_PRIVATE_KEY=n2Z20TgJOtyrysB6eTmifV4lpvtLZlXCEq9fVgg1T5E
SESSION_SECURE_COOKIE=true
REDIS_HOST=X.X.X.13
REDIS_PORT=6379
REDIS_DB=0
REDIS_TIMEOUT=60
CACHE_DRIVER=redis
Output .env server2:
librenms@librenms-poller:~$ cat .env
DB_HOST=X.X.X.13
REDIS_HOST=X.X.X.13
REDIS_PORT=6379
REDIS_DB=0
REDIS_TIMEOUT=60
CACHE_DRIVER=redis
#APP_URL=
INSTALL=true
NODE_ID=67dbdfc8cb0ce
VAPID_PUBLIC_KEY=BIiIwwfqghtBVPTtM1J4hZkmSspe4SMcjj2L7rPeX3DwWhNhSKtQwjoc-8E7q1r7ZciznUO2NR5ilT4d_-gGPTk
VAPID_PRIVATE_KEY=4NlEF2rSLdBPLnAWdt__Gc1imYuEmHznt9T5PECPhoQ
Output webserver /etc/default/rrdcached:
BASE_OPTIONS=“-B -F -R -l 0:42217”
BASE_PATH=/opt/librenms/rrd/
DAEMON_GROUP=librenms
DAEMON_USER=librenms
DAEMON=/usr/bin/rrdcached
JOURNAL_PATH=/var/lib/rrdcached/journal/
PIDFILE=/var/run/rrdcached.pid
SOCKFILE=/run/rrdcached.sock
SOCKGROUP=librenms
WRITE_JITTER=1800
WRITE_THREADS=4
WRITE_TIMEOUT=1800
Output server2 /etc/default/rrdcached:
doesn’t exist
Output webserver /etc/redis/redis.conf:
bind X.X.X.13
Output server2 /etc/redis/redis.conf:
doesn’t exist
Output webserver config.php:
$config[‘distributed_poller’] = true;
$config[‘distributed_poller_name’] = php_uname(‘n’);
$config[‘distributed_poller_group’] = 0;
Output server2 config.php:
Output webserver /etc/mysql/mariadb.conf.d/50-server.cnf:
bind-address = 0.0.0.0
And I have applied the lnms command: lnms config:set rrdcached “X.X.X.X.13:42217” on both machines.
When I start the service on server2, everything is ok for a while, I see both servers in the /poller section active and polling, but the second one writes to the rrd folder on the server2 machine. Shouldn’t it write only in the rrd folder of the webserver? I don’t have the same space for the webserver as for server2 and my disk space fills up and then LibreNMS crashes.
Thanks in advance to everyone, and any help is welcome.
