I can’t seem to find a list of supported software, specifically databases, is there one?
The reason I’m asking is I’m having two problems since upgrading to MySQL 8.0.15 (running latest LibreNMS master) which seems to be related to changes made in MySQL. I did however see there was a change in LibreNMS 1.48 related to MySQL 8 (https://github.com/librenms/librenms/pull/9668) so it seems that there has been work to support it.
Problem 1)
This problem is with dashboards and widgets, LibreNMS is not able to load or save them in the database due to reserved keyword ‘row’ that was introduced in MySQL 8.0.2.
Log output:
[2019-03-03 22:53:27] production.ERROR: SQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ',size_x,size_y,refresh FROM users_widgets
LEFT JOIN widgets
ON widgets
’ at line 1 (SQL: SELECT user_widget_id,users_widgets.widget_id,title,widget,col,row,size_x,size_y,refresh FROM users_widgets
LEFT JOIN widgets
ON widgets
.widget_id
=users_widgets
.widget_id
WHERE dashboard_id
=2) (SQL: SELECT user_widget_id,users_widgets.widget_id,title,widget,col,row,size_x,size_y,refresh FROM users_widgets
Testing a little gives this:
mysql> SELECT col,row,size_x,size_y,refresh FROM users_widgets
ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ',size_x,size_y,refresh FROM users_widgets
’ at line 1
| col | row | size_x | size_y | refresh |
| 13 | 1 | 8 | 4 | 60 |
1 row in set (0.00 sec)
According to https://dev.mysql.com/doc/refman/8.0/en/keywords.html ROW
became reserved in 8.0.2.
Problem 2)
I havent noticed any real world impact from this error except for the validate script; it complains about all timestamp columns.
-bash-4.1$ ./validate.php
Component | Version |
LibreNMS | 1.49-2-g7f104d4 |
DB Schema | 2019_02_10_220000_add_dates_to_fdb (132) |
PHP | 7.3.2 |
MySQL | 8.0.15 |
RRDTool | 1.3.8 |
SNMP | NET-SNMP 5.5 |
[OK] Composer Version: 1.8.4
[FAIL] Database: incorrect column (alerts/timestamp)
[FAIL] Database: incorrect column (alert_log/time_logged)
[FAIL] Database: incorrect column (applications/timestamp)
[FAIL] Database: incorrect column (authlog/datetime)
[FAIL] Database: incorrect column (bill_history/updated)
[FAIL] Database: incorrect column (bill_port_counters/timestamp)
[FAIL] Database: incorrect column (component_statuslog/timestamp)
[FAIL] Database: incorrect column (devices_attribs/updated)
[FAIL] Database: incorrect column (device_mibs/last_modified)
[FAIL] Database: incorrect column (device_oids/last_modified)
[FAIL] Database: incorrect column (mibdefs/last_modified)
[FAIL] Database: incorrect column (ports_adsl/port_adsl_updated)
[FAIL] Database: incorrect column (proxmox/last_seen)
[FAIL] Database: incorrect column (proxmox_ports/last_seen)
[FAIL] Database: incorrect column (sensors/lastupdate)
[FAIL] Database: incorrect column (state_translations/state_lastupdated)
[FAIL] Database: incorrect column (syslog/timestamp)
[FAIL] Database: incorrect column (users/updated_at)
[FAIL] Database: incorrect column (wireless_sensors/lastupdate)
[FAIL] Database: missing constraint (wireless_sensors/wireless_sensors_device_id_foreign)
[FAIL] We have detected that your database schema may be wrong, please report the following to us on Discord (https://t.libren.ms/discord) or the community site (https://t.libren.ms/5gscd):
SQL Statements:
ALTER TABLE alerts
CHANGE timestamp
timestamp
timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP on update CURRENT_TIMESTAMP;
ALTER TABLE alert_log
CHANGE time_logged
time_logged
timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP ;
ALTER TABLE applications
CHANGE timestamp
timestamp
ALTER TABLE authlog
CHANGE datetime
datetime
ALTER TABLE bill_history
CHANGE updated
updated
ALTER TABLE bill_port_counters
CHANGE timestamp
timestamp
ALTER TABLE component_statuslog
CHANGE timestamp
timestamp
ALTER TABLE devices_attribs
CHANGE updated
updated
ALTER TABLE device_mibs
CHANGE last_modified
last_modified
ALTER TABLE device_oids
last_modified
ALTER TABLE mibdefs
last_modified
ALTER TABLE ports_adsl
CHANGE port_adsl_updated
port_adsl_updated
ALTER TABLE proxmox
CHANGE last_seen
last_seen
ALTER TABLE proxmox_ports
CHANGE last_seen
last_seen
ALTER TABLE sensors
CHANGE lastupdate
lastupdate
and 5 more…
Looking at the just the first table everything looks fine.
mysql> show create table alerts;
| alerts | CREATE TABLE alerts
id
int(10) unsigned NOT NULL AUTO_INCREMENT,
device_id
int(10) unsigned NOT NULL,
rule_id
state
int(11) NOT NULL,
alerted
int(11) NOT NULL,
open
int(11) NOT NULL,
note
text CHARACTER SET utf8 COLLATE utf8_unicode_ci,
timestamp
timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP ON UPDATE CURRENT_TIMESTAMP,
info
text CHARACTER SET utf8 COLLATE utf8_unicode_ci NOT NULL,
PRIMARY KEY (id
UNIQUE KEY unique_alert
(device_id
,rule_id
KEY rule_id
(rule_id
KEY device_id
(device_id
) ENGINE=InnoDB AUTO_INCREMENT=267 DEFAULT CHARSET=utf8 COLLATE=utf8_unicode_ci |
Running the suggested queries does nothing to change the vlaidate output and I’ve tried several different DEFAULTs and variations. My guess is that something is returned differently in MySQL 8 that doesn’t match up with the validate check.
Thanks,
-David
