Processor Usage and Storage Usage No Graph
Hi, please help me…
If i am in the wrong place, please let me know.
my libreNMS can’t show the Processor Usage and Storage Usage graph.
For localhost that i have added can show graph of processor usage but not with storage usage including the another host that i have added.
My localhost OS and installed libreNMS is CentOS 7 and my another host is FreeBSD 11.1.
and this output of ./validate.php
[root@nms librenms]# ./validate.php
LibreNMS 1.33-199-gb9dc777
DB Schema 221
PHP 7.1.11
MySQL 10.2.11-MariaDB
RRDTool 1.4.8
SNMP NET-SNMP 5.7.2
[FAIL] Discovery has never run. Check the cron job
Forgive me if you are confused with my english.
I have tried the all solutions i can found but not succeeded yet.
Thanks for anyone who wants to help
If it’s an issue with the WebUI then please consider including the browser version you are using.
you need to check and see why your discovery is not working its inside /etc/cron.d/librenms
Also try: https://docs.librenms.org/#Support/FAQ/#why-do-i-not-see-any-graphs
@Kevin_Krumm this my /etc/cron.d/librenms file
#Using this cron file requires an additional user on your system, please see install docs.
15 0 * * * librenms /opt/librenms/daily.sh >> /dev/null 2>&1
          • librenms /opt/librenms/alerts.php >> /dev/null 2>&1
what do you think is wrong with my cronjob file? i have never edited this file before.
@laf i have use that file …this my snmpd.conf file
#Change libreNMS to your preferred SNMP community string
com2sec readonly default libreNMS
group MyROGroup v2c readonly
view all included .1 80
access MyROGroup “” any noauth exact all none none
#Update the location here
syslocation City, Country [GPSX,Y]
syscontact admin [email protected]
#Distro Detection
extend .1.3.6.1.4.1.2021.7890.1 distro /usr/bin/distro
OK, it has solved now…
I realize librenms cron script didn’t run well after ./daily.sh don’t running too…
So i added some line on the top crontab of librenms like this
SHELL=/bin/bash
PATH=/opt/librenms:/sbin:/bin:/usr/sbin:/usr/bin
MAILTO=root
just my humble suggestion
maybe can added in librenms.nonroot.cron too in librenms source
Thanks for assistance
