Hello Everyone,
Having issues with the initial installation. PHP errors are below. I looked at other posts and had no luck. Additionally, I have copied files from cp /opt/librenms/dist/librenms.cron /etc/cron.d/librenms. However, the guide we were using said to copy from cp /opt/librenms/librenms.nonroot.cron /etc/cron.d/librenms. This file was not there, so I could copy it from the first location.
| LibreNMS | 23.5.0-21-gf4c739c17 (2023-06-18T23:22:41-04:00) |
| DB Schema | 2023_05_12_071412_devices_expand_timetaken_doubles (252) |
| PHP | 8.1.20 |
| Python | 3.6.8 |
| Database | MariaDB 10.3.35-MariaDB |
| RRDTool | 1.7.0 |
| SNMP | 5.8 |
[OK] Composer Version: 2.5.8
[WARN] You have no devices.
Consider adding a device such as localhost: /addhost
[OK] MySQl and PHP time match
[FAIL] No active polling method detected
[FAIL] Python wrapper cron entry is not present
Modified Files:
bootstrap/cache/.gitignore
logs/.gitignore
rrd/.gitignore
storage/app/.gitignore
storage/app/public/.gitignore
storage/debugbar/.gitignore
storage/logs/.gitignore
[FAIL] You need to run this script as ‘librenms’ or root
