Python3 module Required version not satisfied
|Version|21.10.0-106-g63b174595 - Thu Nov 11 2021 09:08:36 GMT-0700|
|Database Schema|2021_10_20_224207_increase_length_of_attrib_type_column (224)|
|Web Server|Apache/2.4.38 (Raspbian)|
|PHP|7.3.31-1~deb10u1|
|Python|3.7.3|
|MySQL|10.3.31-MariaDB-0+deb10u1|
|Laravel|8.65.0|
|RRDtool|1.7.1|
Validate.php fails
[FAIL] Python3 module issue found: 'Required packages: [‘PyMySQL’, ‘python-dotenv’, ‘redis>=3.0’, ‘setuptools’, ‘psutil’, ‘command_runner>=1.3.0’]
Required version not satisfied: (psutil 5.5.1 (/usr/lib/python3/dist-packages), Requirement.parse(‘psutil>=5.6.0’), {‘command-runner’})
pip3 install -r /opt/libre
Output from pip3 install -r /opt/libre
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: PyMySQL in /usr/lib/python3/dist-packages (from -r /opt/librenms/requirements.txt (line 1)) (0.9.3)
Requirement already satisfied: python-dotenv in /usr/lib/python3/dist-packages (from -r /opt/librenms/requirements.txt (line 2)) (0.9.1)
Requirement already satisfied: redis>=3.0 in /usr/lib/python3/dist-packages (from -r /opt/librenms/requirements.txt (line 3)) (3.2.1)
Requirement already satisfied: setuptools in /usr/lib/python3/dist-packages (from -r /opt/librenms/requirements.txt (line 4)) (40.8.0)
Requirement already satisfied: psutil in /usr/lib/python3/dist-packages (from -r /opt/librenms/requirements.txt (line 5)) (5.5.1)
Requirement already satisfied: command_runner>=1.3.0 in ./.local/lib/python3.7/site-packages (from -r /opt/librenms/requirements.txt (line 6)) (1.3.0)
pip3 install -U -r requirements.txt
Perfect, thanks!
