Librenms is working great, but I am curious if there is a way to create a pane on the dashboard that shows
Top ports with discards
Top devices with high cpu usage
Top devices with high memory usage
Even if this is not on the dashboard is there a way to display all this on one page?
Yes with the widgets.
But not with Top ports with discards
Also see here Home - LibreNMS Docs
perfect 2/3 of the way there. Is there any way to aggregate the top discard data into one view in librenms?
Thank you for the quick response! I may just dump that data into influx and graph it with grafana.
