does anyone have any insight in to what “Disable Alerting” does for alerts?
we had a maintenance window to reboot the gateway before our Libre server, and so instead of setting a maintnence window for each device, I set Disable Alerting to true. after the maintence was over, I set Disable Alerting to false, but I got every notification that would have been sent anyway. It’s as if all I did was postpone the alerts until they were enabled again
