Comparing the graphs for number of wireless clients shows different numbers for different time periods. For example, when viewing the graph for the last two months, the daily peak is around 1,000 clients. But if I change the view to 1 year, the peaks over those same months is almost half that, at around 600 clients.
Why does a 1 year graph show such a different number from the graphs of shorter time periods? Is there anything I can do to get the numbers to match? I want to graph peaks, not averages, even over 1 or 2 years.
