If you are running into this issue:
[OK] Composer Version: 1.8.2
[FAIL] Database: incorrect column (sensors/sensor_id)
[FAIL] Database: incorrect column (sensors_to_state_indexes/sensor_id)
[FAIL] Database: incorrect column (sensors_to_state_indexes/state_index_id)
[FAIL] Database: missing index (sensors_to_state_indexes/state_index_id)
[FAIL] Database: extra index (sensors_to_state_indexes/sensors_to_state_indexes_ibfk_1)
[FAIL] Database: incorrect column (state_indexes/state_index_id)
[FAIL] We have detected that your database schema may be wrong, please report the following to us on Discord (https://t.libren.ms/discord) or the community site (https://t.libren.ms/5gscd):
SQL Statements:
ALTER TABLE `sensors` CHANGE `sensor_id` `sensor_id` int(10) unsigned NOT NULL auto_increment;
ALTER TABLE `sensors_to_state_indexes` CHANGE `sensor_id` `sensor_id` int(10) unsigned NOT NULL ;
ALTER TABLE `sensors_to_state_indexes` CHANGE `state_index_id` `state_index_id` int(10) unsigned NOT NULL ;
ALTER TABLE `sensors_to_state_indexes` DROP INDEX `sensors_to_state_indexes_ibfk_1`;
ALTER TABLE `sensors_to_state_indexes` ADD INDEX `state_index_id` (`state_index_id`);
ALTER TABLE `state_indexes` CHANGE `state_index_id` `state_index_id` int(10) unsigned NOT NULL auto_increment;
And running those statements returns errors like:
ERROR 1025 (HY000): Error on rename of 'sensors_to_state_indexes' to '#sql2-114d-a6d78' (errno: 152)
or
ERROR 1553 (HY000): Cannot drop index 'sensors_to_state_indexes_ibfk_1': needed in a foreign key constraint
This is what you have to do:
mysql -u librenms -p librenms < sql-schema/278.sql
This will ask for your sql password. It is in the .env and config.php files.
And then run ./daily.sh
again
