Hi all,
is there a way to set the Default level of a user inside the Radius DB?
My radius checks a table to see what IP is allowed to try and Auth when radius sees that the ip is allowed to try and auth it moves over to a new table to check if the user exists so is there then a way to tell librenms that the user exits and is a admin, without having to change it manually.
and then I saw with radius auth we lose the option to Manage access
